shifting problems
terrylee
Hello again I,m working on a mercrusier alpha one out drive pulled the lower unitoff to change the impellar would not shift so pulled it back off today made sure the throttle was in forward turned the prop ccw and made sure the shifting arm was all the way clockwise now my question is that part that goes on the shifting arm suppose to be just hanging down floppy or is it suppose to be tight
Haut Medoc
Re: shifting problems
If the upper & lower are separated, yes......
If they are together, it means you left out the washer that sits over the shift shaft......;)​
