77_starcraft
Thread starter- Joined
- Oct 8, 2007
- 55
Sorry for the long story, but here's the 30 yr history....
I have a 1978 Evinrude 115 that seems low on power. The boat has seen a lot of use since about 1990. Don't have an hour meter but I'm sure there are a lot of hours now (200-300?). It has had good routine maintenance and some various repairs (carbs, ignition) over the years. Performance seems to have slowly slipped over the years.
Primary use is a ski/air chair tow boat, but won't get a slalom ski out of the water. I have aerated the 19" prop, which helped a lot. A 17" prop is worse in both takeoff and top speed. The aluminum hulled boat will only do 35mph(GPS) at about 4400rpm (w/ 3 adults, good conditions). Full of gas, it probably doesn't weigh more than 1500 pounds. I have a planeing (sp?) fin that helps out on slow cruise speed, but doesn't effect top end much (anymore).
What should the compression numbers be for this engine? My dad put some thicker head gaskets on it 15 years ago to run in 87-89 octane gas (still did 40 mph+ back then). My plan was to run the engine a few min with muffs and then do the test.
Anyone know of a good outboard shop in Phoenix AZ?
I was also thinking of stock head gaskets and upgrading to 140 carbs. was this the only difference between the 115 and 140?
Does the boat need to be at WOT in the water to check the timing? can I use a regular automotive timing light hooked to #1 cylinder?
