Re: 1990 merc 115 2+2 elimination
The bottom 2 carbs are the ones that would need to be replaced (they do not have low speed jets).
If you try this, please post your results. I would be very interested to hear how it works. I've read many opinions on whether this would work or not, but I don't ever remember hearing from someone that actually did it.
I have a 1998 115 2+2 and for a time I hated the 2+2 design and wanted to do what you are suggesting. Since then, I learned and fiddled and now mine runs great and I'm happy with the way it runs.
Here are my tips for making the 2+2 run well:
1) Do a complete link-n-sync per the manual to assure that everything is set up properly
2) Do a decarb
3) Prop your boat so that your running at 5250 RPM (or very close to it) at WOT. These engines do not like to be lugged, and being over propped makes it more difficult to switch from 2 to 4 cylinders.
4) Gap your plugs at .032 instead of .040 as the factory suggests.
After doing these 4 steps, my engine runs great. It rarely misses or stumbles when I put the hammer down. 99% of the time it just pops from 2 to 4 cyls, with an authoritative bite. Of course if I hang around 2000 rpm it stumbles and misses as it alternately runs on 2, 3, and 4 cylinders, but that is the design and is to be expected. On my setup the boat is just crawling up on plane at 2K rpm, so I would never hang there anyway.
Let us know what you find. If I had the extra carbs sitting around I'd do it just to find out if it works. Wouldn't take much to switch it back if you didn't like it.
