rob johnson
Thread starter- Joined
- Oct 10, 2007
- 4
I just thought I'd redefine the problem I mentioned earlier in hopes that some more information might help. This is a 2001 50hp 4-stroke mercury bigfoot that has been setting off the overheat alarm and I tried to fix by replacing the t-stat, water pump and backflushing, all no improvement, infact, worse. Now the alarm happens more frequently and the tell tale stream still isn't producing like it should. The owner also complains of loss of RPM. Almost 1000 RPM at WOT. When I changed the spark pluggs they were light chocolate brown on one side of the insulator, and crusty black on the other side of the insulator. That is to say, dividing the insulator into 2 semi circles; one half black, the other half normal. Does anyone have any ideas that can help? Maybe the RPM loss and overheat are connected? I appreciat any and all suggestions. Someone in the other string suggested the poppet valve, but I have no idea what that is or where it is. Does anyone have a picture of this? or a location? Thanks for reading!!
Rob
Rob
