1985 carver montego merc 350 alpha one neededhelp
bolo78910
hello guys i am back, been away for too long lol.
ok i sold the last project, now i have another one, the owner stated five year ago he install a reman 350 merc, took it for a cruise and he herd banging noise coming from the engine.
he stated he got **** of and never took the boat out again,
now its five past years and this boat just fell into my lap lol.
help me here now guys was told the drive is almost new , from the look it does look new, ??? after five year the gas in the tank has to spoil, before i try start it should i drain the tank and put fresh gas??
i wil try turn the engine by hand before i crank her up, i will also change the oil, water separator filter what else guy?
last the the guy stated the knock was at the bottom of the engine. what is the possible to espect.
thanks for any info you guys will post.
bolo
bolo78910
Re: 1985 carver montego merc 350 alpha one neededhelp
ok here we go , went to the boat today one big mistake i make was not taking a test light with me,
first i put a big screw driver on the damper and turn the engine real easy.
i get no keys with the boat so i bought a new key switch and install it.
when i try crank the engine i got nothing, not even a click.
now i head down to the slave solenoid and jump it with my screw driver, now the engine turn over.
as i said i did not have my test light with me so i just leave it at that,
will post my find after fishing around in the morn.
bolo78910
thanks don real helpfull as usial, went back to the boat today first i got the key switch working it was the fuse for the key switch was blown.
now don i realy need yall help on this, when i start the engine it kinda runs rough with a slight knock, i notice water was getting in the bilge so i turn the engine off, gess what one freezer plug is missing i stick my finger all the way in.
so could this freezer pleg cause the engine to run a little loud and rough???
last sopose the noise is coming from the lower bering is that a easy fix by just dropping the oil pan and put new bering and seal.
thanks for yall info on this.
bolo78910
still dont wana start a new tread, can i perchase the rod bearings from a autopart store, if the bearing is the shot??
wow it seem this forum is not what it use to be, where the hek is every body????
bolo78910
bump
Don S
You aren't going to change any bearings with the engine in the boat. If they are bad, there is probably going to be crank damage and probably metal shavings that will have to be cleaned out.
If a freeze plug popped out, it probably froze, and may have cracked the block. Did you check the oil to see if it was milky or way over full?
Over full could also make the lifters rattle.
bolo78910
yea dons thanks i konw i would have to pull the engine, this is my final up date, i install one freezer plug portside rear, start the engine only to find out starboard engine lost a freezer plug also, install that one too.
start the engine runs fine no real miss only the knocking from the bottom not the top.
now don if you was in my shoes with money kinda low right now. i know a few guys in my area who can install new bearing ect .
what else should they cut /change to do a perfect job .
i run the engine for a long while, no milky oil. no high oil level on the dip stick, the oil guage still hold good preasure,
is this a big job how much a job like this should cost??
please walk me through. the engine was a new reman. thanks
Don S
Let me put it this way. If it blew 2 core plugs out of it from freezing, and is also knocking, I wouldn't waste any time or money on it at all. It will require a complete disassembly and inspection to find ALL the problems.
Yes, it's a big, expensive, job. It's called an engine rebuild, and if done improperly will blow up again, and again, till it's done right.
bolo78910
been listening to you for a long time don , and i will not stop now, verdic is i will get a short block or a long block and just switch the good parts over to the new block.
thanks so much, i will keep yall posted. of the out come.
bolo78910
hi don can you tell me what year engine serial # is this i just need to get the right block.
serial #14093638
thanks this is from the bad engine in the boat.
JustJason
uhmmm is that dude drunk typing??????
BAYLINER185
If the boat fell into your lap fairly cheep then why mess with rebuildign an old motor or 2.
Just buy new motors or rebuilt motors complete. I would.
It would be a lot less work and time consumed right? Granted winter is comming so maby rebuilding a motor fo rnext season is a cool project if you know what your doing I guess.
I dont think the dude is drunk I thinks maby bad english LOL....:D
Don S
Perfect English is not a requirement to fix a boat, or ask a question on these forums. As long as the idea is conveyed.
Wait till you see a 200 word question in one word...............No spaces, puctuation, capitalization or anything.......... That, is a problem.
ifyoudontbelievemejusttryreadingthis
JustJason
very true.... but i will say that VERY GOOD english is required to understand half of the service manuals out there!!!
Except for VP.... and especially the older ones... then in that scenario bad english is your better bet.
Note:from VP service manual.
step 1. dissasemble double bearing box.
step 2. remove gearset.
step 3. this may be very difficult.
i've actually seen lines similar to this in older vp manuals..
BAYLINER185
Lol
This May Be Very Difficult
rodbolt
4, using a suitable tool
5,tap with rawhide mallet.
:) jinglish is about as good as swinglish :)
if ya really really want a laugh look up the VP method to set the bearing preload on the intermediate housing for a jack shafted swedish drive. now that is truly funny,.
but back to the issue.
if it popped 2 core plugs odds are high its cracked exhast manifolds,risers and any oil coolers.
I get 4 or 5 craked engines every spring as it doesnt get cold enough to freeze here :).
bolo78910
its a amazing, you post for some good info, and guy who have nothing positive to the subject , just keep posting trying to be funny. i will say yes some times i just tipe and dont go over it befor i post, but what the heck yall understant what i am getting at.
thanks again don. i will be getting a long block from rapido . just dont want to mess with that old knocking engine.
from what i was told the guy who owns the boat before, install a new reman took it out, and it start knocking, all the parts look great like new, so when i get the rapido engine i will just start stripping .
