Nandy
Thread starter- Joined
- Apr 10, 2004
- 2,145
I took time today to work on that motor I bought. It is a 1975 70hp 70573-b Evinrude. When I bought the motor/trailer/boat combo all I did was check for spark. The previous owner took the top carb out about 13 years ago or so and the boat has not been used since as the gentleman passed away.
I put that carb back, made an impromptu throttle link as the original one was lost as well as the carb nuts. I lubricated the motor with a bit of fuel mix via the sparkplugs and gave it a few turns, then shoot a bit of mix from the carbs, put the plugs but not the ignition cables, a few revolutions and I was ready for a real start. I connected to the gas connector and prime the bulb. It got hard real quick, the motor started but died real quick. A mud dabber had put a nest in the motor gas connector. I connected the gas straight to the pump filter and will clean that connector later.
The motor started real quick but I could not see the tattle tale stream of water. Shut it down real quick and went checking to make sure another mud dabber had made a nest. Well guest what, there is no tattle tale port. I felt a little stupid, now this take me to my next point.
I really want to have a way to tell that the water pump is not working other than the overheat buzzer going off. I have read about the possibility of making a hole into the water jacket and making your own tattle tale port. Or even installing a water preasure gauge. Anyone here has experience with that procedure for this motor? Also, how do I test that overheat sensor, is that thermostat sensor normally grounded or normally open?
Thanks!
Thanks!
