cjnspecial
Thread starter- Joined
- Oct 13, 2007
- 5
Hey Yall,
I put a seal kit in the lower unit(prop seals, shift shaft seal, bearing carrier o-ring, complete water pump, etc) and reverse would not engage. I dropped the lower unit again and moved the shift shaft lever to the reverse position and turned the prop to be sure the clutch was engaging reverse gear. Well....the gears will engage if I turn the prop(CW) slowly but if I put any torque on it or try to spin it quickly, it just slips. Foward and neutral work fine. Before I re-install the l/u, is this normal?
Any help or advise you can offer is greatly apreaciated.
