I just acquired a 25 hp. 1974 Evinrude. She'll run great at idle and up to about mid range but soon as you pour the coals to her she bogs out and dies. If you pull the choke open the RPM comes up pretty good but not 100%. If you fiddle with the carb linkage with the throttle wide open it will come up and run at top RPM just fine.
What the heck is going on. Do I have a plugged up carb??
Is carb linkage screwed up? Any suggestions??? Thanks much in advance!!!
