boats on a budget
thrasher
Re: boats on a budget
I'm about to strip my interior as well!! hope to get a few posts and some good information from this site.
Gary
Mr.Stuart
Gary
Oh you will, these guys are good, I'd still own a Maxum 21 foot cuddy with a merc L-Drive if it wasn't for these guys telling me to run from it, the day I got rid of that boat was trully the happiest day of my life! then came the starcraft, and now this little 12 footer, I'm a happy boater now.
look at some of the old guys post count, like mine. post count is nothing, the quality of the info is what is important.
Andy in NY
wow, just read through the whole thread. mr stuart, quite an experience you have going!
Mr.Stuart
hey, thanks, I'm enjoying working on it, I do go through moments of frustration, but I keep picturing what it's going to look like when I'm done, and that keeps me going on it.
when I did the short shaft conversion on the outboard, I decided to put the long shaft stuff for sale on ebay, I noticed other long shaft parts on there, and the starting prices were $150, I'd be happy to get anything out of mine, and sure wasn't expecting to get 150 out of it, so a couple of weeks ago, I posted it for sale for $80.00 or best offer, the ad ran for a week, and I didn't get a single offer or bid, so I reposted it last week and started the bidding at 99 cents, the auction closed last night and the long shaft stuff sold for $90. I'm happy with that, that gives me $90.00 to put towards the inside of the boat, and it should carry me a long ways.
I'll take the 90, and put it towards the stripper and gluvit, from reading another thread, I think I'm going to go with the oven cleaner to get the inside of the boat stripped, I'm told "easy off" is my best bet.
chuck_050382
let us know how the oven cleaner works. I have a 50's 12 footer that i want to strip and repaint the inside and either polish or paint the outside.
Mr.Stuart
I'll let you know how it works out; I'll get pictures of the oven cleaner in action.
A friend of mine has a heated garage, so I'm going to do the painting there, I'll get the inside stripped and ready to go, then haul the boat to his house for the painting, he doesn't want any spraying in his garage, but I'm sure I can do it and have it look reasonably good with brushes and or rollers, or could probably get away with maybe some rattle can primer or something, I'll cross that bridge when I get to it, I need to finish stripping the wood out, and get the inside prepped for refinishing.
for the outside of the boat, I think I'm going to go with my origional plan and polish it, unless someone has a better idea.
Mr.Stuart
my next question would be:
do I need to seal the leaky areas with something, there's only a couple of small spots the drip water just a little bit, it's hardly anything at all, so will the cluvit do the job of sealing it up, or do I need to use something else in the problem areas before I apply the gluvit?
jspringator
I'm going to use this "Durabak" stuff when I paint my jon boat. Light grey textured on the inside, light grey smooth on the outside. Can be rolled and brushed on. I ordered a technical brochure with surface prep requirements, including priming. Here is the site: "http://www.durabakcompany.com/marine2.htm"
thrasher
would it also make sense to run another leak test after you have stripped the paint? Just wondering if the paint is sealing some small holes which after you strip will start leaking? It would be a real shame to have to repair the boat after you have finished painting it..
Gary
Fish n Geer
Well im just learning,but from what i have learned so far is.He will strip the old paint,apply the gluvit then paint it.Should do the trick! Give her hell Mr Stuart looking good! I am real curious about this oven cleaner deal?Was wondering on how that would work on my glue removal project.
Mr.Stuart
I'll check out that durabak stuff, my thought was to pant it with rustrolium, kind of working along the lines of keeping it low cost, from what I understand, you can paint over the gluvit.
doing another leak test isn't a bad idea, it's easy enough to do, and I have the boat well supported on the trailer now.
I was going to do some more wood removal on the boat today but got side tracked with another small job, fixing a computer for the guy with the garage .....that's how I came across the garage to paint the boat in, I'm going to try to get some more wood out of it tomorrow, as easy as it looks to get that wood out, it's not going so well, it's got years and layers of paint over the screws, they don't look like they were stainless steel, their all rusty, and I'm trying to remove the wood with out to much damage to it so I can use the old wood as a pattern for the new stuff, plus I'm trying to not damage the mounting hardware in anyway, it took me a good hour and a half or so just to get that front seat out of it.
I've read a few threads on using the oven cleaner, from what I've seen it's only references to people either having used oven cleaner, or are going to use it, but I haven't seen anything yet that shows the oven cleaner actually doing it's thing, so I figured I'd give it a try and post pictures here as I go, at least your going to know if it works, how well it works, and how hard or easy it is to work with.
This whole boat thing is new to me, I've never ventured into a project like this before, this is a learn as I go project. so I'll be the first to admit, I have no idea what I'm doing, that's why I'm so open to the ideas and suggestions you people have.
the other thing I'm not finding much information on is the slat flooring, that's the first thing I need to install in the boat after it's painted, and I'm not finding much info on how the pro's do it, so that's an area where I'll be winging it.
My guess is that I'll be able to strip, prep, gluvit and paint on the same day, once I get all the wood out of it, I may be way out in left field with with that prediction, but that's my best guess at this point. I figured with a heated garage, I should be able to finish the interior pretty quick.
I'm an all weather kind of person, so working in the rain and cold doesn't bother me, sometimes your best camping is during the winter months when no one else is on the mountain, and this boat will be getting used during the winter months, I really don't see anything I can't do to the boat in bad weather other then painting and wood staining, but I can do the staining in the house after I get the parts cut out.
these are just some of my thoughts.
Stuart
tmcalavy
The oven cleaner will take the paint and crud off down to bare metal. Be sure this is what you want. Don't know how it would fare removing other substances such as glue. The Ezy Off cleaner is basically sodium hydroxide in a spray can, if you remember chemistry you know that caustic stuff so wear proper protection.
Mr.Stuart
there's not much paint left in the boat, it's about 90% gone already just from age, there's a few rivets in the back bottom of the boat that have some sort of sealer over them, I figured I'd clean all that out before I put the gluvit on.
I figured the oven cleaner would do some serious stripping, but that's ok, because I was planning on using the gluvit to re-seal anyway.
my plan is to strip, prep, apply gluvit, then some self etching primer, then paint
Mr.Stuart
I got the center bench out, pictures to follow, I ran out of time and had to go to work.
the center and rear benches have floatation foam under them, not sure if I should put it back, or chuck it and turn the center bench into a cooler, and the rear bench into storage.
kwikk9
Mr. Stuart, You have to quit work and go full time on this restoration, I can't take the suspense. How did the ez-off oven cleaner work on the paint strip job?
I have a 10' Sears (c.1976) aluminum skiff that came free with my camp. Original green was repainted as red, yellow, blue probably by some 10 year olds. It's a sad boat and I was going to recycle it at the transfer station. Now I'm thinking I can salvage it.
Mr.Stuart
Mr. Stuart, You have to quit work, I can't take the suspense. How did the ez-off oven cleaner work on the paint strip job?
I have a 10' Sears (c.1976) aluminum skiff that came with my camp. Original green was repainted as red, yellow, blue probably by some 10 year olds. It's a sad boat and I was going to recycle it at the transfer station. Now I'm thinking I can salvage it.
if it's not to beat up, and don't leak to bad, I'd say salvage it, new paint can do wonders. I have't done the oven cleaner thing yet, I'm still working on getting the wood out of the boat, I threw my back out today working on the center bench, so I'm a little sore tonight, but plan on doing some more this weekend, and possably start the stripping prosess, I got pictures of wht I've done so far, but ran out of time and didn't get a chance to upload them to the computer.
