I'm hoping someone out there can help with my 1999 90 HP Johnson. I purchased the boat and motor new in 1999 and have never had any problems with the package. Unfortunately, at 177 hrs. I decided to complete some maintenance items. I had a local repair shop replace the water pump and thermostats. I thought I could handle the decarbonization. This is when my trouble started. I followed the directions on the can and even had the repair shop give me directions before I started. There is a red knob under the plastic breather with a male end on it for the decarbonization can fitting. I emptied the can per the shop directions into the fitting infront of the red knob. The motor smoked like there was not tomorrow but ran fine afterwards. I guess I moved the red knob from its original setting and I have no idea where it should be set. The worse part is I cannot start my motor now. I have taken the brand new plugs (gapped correctly) out wiped them clean but I all the motor does is turn over. It tries to start by coughing as it turns over but it will not start. Any help would be greatly appreciated!
Walter
Walter
