Don't Know What to do next!
DuckHntr
Please Help. I have been reading and tinkering for weeks now to no avail. I have a '74 Chrysler 25 hp elect start. all was running well last season till i lost 1 cylinder. i have replaced the coil on that side, the points, the condensors and the plugs. spark is now good, compression is good and it will run on the single cylinder. when i turn it over with the plugs out i get a mist of feul out of both cylinders. i was reading about squeezing the primer bulb until FIRM so i did this to try to start today to decarb. i squeezed and squeezed and noticed fuel pouring out of the LU and exaust snout.
Anyone that can tell me where to go from here iwould greatly appreaciat it.
eurolarva
Re: Don't Know What to do next!
You will need a rebuild kit for the carb and you will need to replace the needle and the seat. Iboats sells them. part number 18-7037. Would not hurt to replace the diaphram on the fuel pump as well 18.7806
Here are the links
FUEL PUMP KIT
CARB KIT
