just for ****s and giggles
Ezrider_92356
i have an 14ft alum boat with an 25hp merc, do you think it could pull a skier. its got a hole shot from hell go from idle to full throttle it will pull up on a plane almost as fast as you can blink. one time a passanger sitting backwards in one of the forward seats almost ended up on the floor doing this. but i immagin a skier adds alot of drag
SandMan*
Re: just for ****s and giggles
You need to pull a skier up slowly, if you just launch they will never be able to hold the tow rope.
get a tube, it'll pull that no problem
EricR
I think it will do just fine, I pulled a skier up (slowly, but it did it!) with an 18 horse on on light 12 and a half foot hull.
sangerwaker
You'll have no problems with lighter skiers.
We used to trick ski behind a 12' alum duck boat with a 9.9 when I was growing up.
MikDee
Banned
When I was a kid, we used to water ski off a light 14' plywood boat, and an 18hp Johnson regularly, as long as your skier is under about 200lbs I'd say your fine.
oops!
with the hole shot u described you should be fine. a heavyer person on the end of the rope might be a problem esp if they are new to skiing.
if you have any problems just go to a lower pitch prop!
knee boarding is also a gas! and easy on small motors.
sickwilly
sounds exactly like our first boat, and yes we all learned to ski behind it. We were kids, though.
Frank Acampora
Using two skis, no problem. Slalom ski--Expert skier--Maybe, novice no.
Ezrider_92356
when i posted this i figured everyone would say that the drag of a skier would just dog my boat out and it wouldn't work. seems like everyone always talks about needing big hp to ski. its getting way to cold to be trying water sports out for this year. maby next spring i will have to give it a try. maby by then ill have my 35hp jhonson rebuilt then i should realy not have any problems
duckhunter55
Sorry to jump in on your post, but i have a 14ft. aluminum boat with a 25hp johnson, it will fly too, but i was concerned with where to hook the rope to the boat at. The transom is solid, but that seems like alot of stress on a 15yr old 14ft. boats transom.
