Need Advice. I have a 200hp 2005 Yamaha 2 stroke. This summer i noticed a small drip of oil at the bottom drain screw. I drained the lower unit and pumped new gear lube in. All was fixed. I used the boat and theres a small drip again. I drained it but this time replaced the washers as well. Used the boat and the same thing happened. Drained and replaced the washers again but made sure i rolled them in the oil before installing. Again, after using the boat today i noticed a small drip on the bottom screw. The bottom screw certainly feels like it is seating when i tighten it. Any advice or do I send it to the shop?
