Plug on this boat?
nightvision
Hi all,
A sailing newbie here. I'm a power boater and was given an 1973 Ensenada 20 from a friend who was using it until a couple years ago. My son and I will modestly restore this boat. A couple questions for starter.
a. I can not find a drain plug for this boat. Is it common for sail boats not to have a plug? So am I correct to assume that I will net to put in a bilge pump?
b. This boat have a retractible keel. Is it common for water to enter from this point?
Please educate me! More questions will come later.
Lucky Bum
Aaaaaahhh I had same question
Mr nightvision.
I also,,,,,, drove from Northern Ohio to Southern Tenn to buy a 222 O'day found on e'Bay. Being a power boater too it never dawned on me that boats were built without a sea cocks, yet no bilge pump either. Apparently I missed seeing them when I looked over the boat because it was two weeks after my boat was home that I also discovered the same.. Hummmm Well I decided to not get to excited about it ansd see just how she sails.. Started to ask questions on the various sailboat forums and found a couple people had put in bilge pumps but never used them. One guy put in a manual pump and never has needed it.
You will be glad to know that I just finished my second sailing season. and have never had to even wipe out the bilge with a dry towel. I have had the 222 O'Day's toe rail under water many times but nary a drop of water gets in the bilge. The cockpit is self draining as I imagine yours is too. I am really enjoying my sailboat and have been spending good quality time on the water in my retirement. Just installed a tiller pilot and that's the cats meow.
Welcome aboard the world of sailing. Power boating was good while working as it took 5 min to get the boat ready to turn the key, and the same to put it away. Not to mention last season I used 4 gallons of gas with the sailboat and may use 6 gallons this season.. I worry now with the new gas will it spoil in the tank? Hee he.!
Just tried to add a pix of GETAWAY for you to see, but havn't figured it out yet,, Maybe we can"t
Lucky Bum
Re: Plug on this boat?
Mr nightvision.
__________________
Sailing is not a matter of life or death, it is more important than that.
Lucky Bum
Sorry for the double post!! Learning the forums software,. Maybe the moderator can delete one of my doubles.:p
