CUCULANDRA
Thread starter- Joined
- Oct 22, 2007
- 13
Okay This Is The Problem I Am Having, After The Boat Idles For About A Minute Or 2 The Warning Horn Starts Chirping, ( Not Constant Yet) And The Engine Will Not Rev Past 2800 Rpm Or So. So That Is Safe Mode Right? Well I Dropped The Lower Unit Changed The Water Pump And Gaskets Impeller (everything) I Also Changed The Thermostats. Fired It Up Got A Steady Stream But Then That Horn Chirps Again... I Checked The Temp With A Temp Gun And It Read 155- 163 On Bothe Cylinders. If I Rev The Motor After A While It Will Chirp Constant Untill I Let Off The Throttle. Then It Just Chirps On And Off But Still Won't Rev Past 2800 Rpm Or So. Now If I Unplug Both Temp Sensors Then The Horn Still Chirps On And Off But The Engine Will Rev Past 2800 Rpm. What Do You Guys Think It Is? Please Help
