Scaaty
Thread starter- Joined
- May 31, 2004
- 5,180
I got too many lower units with impellers. I can't be dropping LU/s every spring. That said, my newly crank up 72 135 Merc Stack (less than 10 hours) has those smaller thick impellers that take a set too easy. The whole boat/motor covered, so too much work to hand crank the Flywheel ever month. After starring at it while downing a 6 pack yesterday, the flash hit about beer #5. I uncovered it, loosened all the plugs, put it reverse (it won't work in forward, the ratchet thing), and made sure it wasn't too hard to hand turn the FW. The propshaft turned in reverse. I then stuck the prop on, hand cranked it a touch in reverse. Got the FW to turn about 1/3, so now any compressed blades have moved, replaced with another few. Wrapped it all back up. My plan is go out once a month and give it a slight rotation with the prop (in REVERSE OF COURSE..that a pretty important reminder..go forward, the impeller wil be going the wrong direction and will be junk soon of course)
Thoughts?...or to much beer?
