Tire replacement on SUV
POINTER94
My 2005 Ford Expedition blew out the right rear tire due to a large puncture. The rest of the tires look to have about 1/2 life left. Can I replace the blow tire with a used one of the same make and model or will the differing wear and therefor circumferance create havoc for the differential? What if I put the replacement up front, it is 4wd but almost never is it engaged?
Barnacle_Bill
Re: Tire replacement on SUV
I recently did the same thing with the same tire on an 03 Tundra 4WD. I found a place that had the same tire and had it put on where the bad one was. I can't tell any difference.
Bob_VT
What caused the puncture??? I would be cautious of the other tires until I was sure. If it was a known object then go ahead and replace just one.
scrobo
As with my cars I try to replace 2 at a time. If I lose a rear I replace both rears. Unless there is very little wear on one. I just prefer symmetry I guess. :)
POINTER94
Thanks all for the advise.
I scored a good deal on a set of 4 and took the plunge. The tires had about 60K on them and it just seemed like the right thing to do.....
Bob_VT
Smart!
Manipulator
The Expedition comes with a full size spare. Take the other tire off the rear and use it as your spare and purchase one new tire. You will have a set of new tires on the rear. Same thing happened to me and thats what I did.
