Mine is missing. Can I use a regular s/s clamp or should I get a crimp clamp or can I use a zip tie?
S Shaun78 Petty Officer 1st Class Joined Oct 1, 2007 Messages 276 Oct 27, 2007 #1 Mine is missing. Can I use a regular s/s clamp or should I get a crimp clamp or can I use a zip tie?
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Oct 27, 2007 #2 Re: shift cable bellows crimp clamp I have always installed a fuel line zip tie. They have an end on the tie that completes the circle so there isn't a gap. Merc dealers have them since they are used a lot on outboards.
S Shaun78 Petty Officer 1st Class Joined Oct 1, 2007 Messages 276 Oct 27, 2007 #3 Re: shift cable bellows crimp clamp Do u think i am ok as i don't know how long it's been missing for?
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Oct 27, 2007 #4 Re: shift cable bellows crimp clamp If you don't have water leaking into the boat, then it's not a problem.
S Shaun78 Petty Officer 1st Class Joined Oct 1, 2007 Messages 276 Oct 27, 2007 #5 Re: shift cable bellows crimp clamp Can I get the crimp clamp at home depot?
