Johnson Tilt & Trim Question.....
gregr1971
i have a 1977 200hp johnson(gas hog!), the tilt and trim is trashed, it has the 3 wire motor with the big ugly external solinoid box, my question is, i am looking at a unit from an '87 60hp johnson, 2-wire system, will this bolt in and work on my 200hp, with out any major modifications? i do not want to go back with the 3 wire set up, way too many wires.
here is the one a am about to purchase, if it will work.
http://cgi.ebay.com/ebaymotors/JOHN...ryZ50439QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
gregr1971
Re: Johnson Tilt & Trim Question.....
too small of a unit??
HighTrim
Some of them are rated for 60 to 300 hp, the description is pretty vague, and it does not sound as if you get the relays and box. Check out this link, it is the unit to replace the 3 wire one, and includes the relays and box plus all applicable wiring. They arent cheap though. GOod luck.
"http://www.maxrules.com/fixomctrim.html#ASSEMBLY"
