Hello, I have been lurking and reading everything I can about this engine and tank system. I inherited this motor that has always been garage kept and has probably less than 50 hrs. total run time. The last time that it was used was 1993, date of boat register. When I first tried to crank the engine, it would hit and thats all. After many hours and probably days, if I had kept up with the hours, I now have tank where it works. It is a 6 gallon tank and I spent 230 dollars in parts alone to get it to where it is. Everything was gummed up really bad. I even had to buy a new pick up line for the tank ($$$$$). Now that I have gas to the engine, it would hit and backfired one time. Removed carb and cleaned really good, I am in no hurry at all. I got the carb kit and impellar kit yesterday and will install tomorrow. The only thing about the kit that I do not understand is the packing that goes on the high and low speed jets. The directions call for 1 packing and 1 packing washer to go on each. All that came with the kit is packing rings made of a redish brown composite material, not o rings. I guess that I will put 2 of these packing washers on each jet since I do not live close to a dealer.
