Parts Exchange For 9.9 Evinrude Different Years
CALL2255
Will The Drive Shaft And Shift Rod From A 1980 9.9 Evinrude Fit A 1995 9.9 Evinrude? If Not Where Is Best Place To Get These Parts Used. Thanks
Mr.Stuart
Re: Parts Exchange For 9.9 Evinrude Different Years
Hey, welcome to Iboats! Are you doing a conversion or just repairing one that's broken? I looked up the parts numbers for the two years you mention, and it does not look like their interchangeable.
Stuart
ezeke
Try some of these companies:
sea-way. com
outboard-parts. com
marinepartsoutlet .com
laingsoutboards. com
tcoutboard. com
the machinist
OMC made a model change in the 9.9/15hp in 1993. Totally different powerhead & upper cowlings.
The drive shaft will fit but the shifting linkage is different as the newer motors have a shifting lever mounted in the front of the motor & not on the side like the pre 93s. The lower unit is basically the same (water intake & zincs are different) but about all the other internals including water pump are the same.
CALL2255
I Was Told That The Splines Might Be Different On The Newer Drive Shafts Any Truth To That? Thanks
