ventureman
Thread starter- Joined
- Nov 2, 2007
- 23
Hi everyone: Found this forum yesterday. Just bought a 1977 merc 1500 inline 6 a few weeks ago. Mounted on my boat now. Started after about 15 cranks with last week. It would initially backfire but run fine after that on ear muffs. Smooth idling. Started and stop 3 times without any problems.. Now, I could not get it to run. NO SPARK! on all cylinders. Hook up voltmeter
from red to white terminal and it is showing less than 9 volts. Could be problem with harness, battery, or cables, but I doubt it even though I am supposed to get at least 9.5 volts to start. Checked switchbox, seems ok, not sure about trigger, rectifier seems ok. Suspect coil but not sure. Also starter bendix sometimes stick to flywheel, not sure if I am getting enough juice to fire, but it does turn pretty fast. My external harness however is old and warped. I retaped with electrical tape. Previous motor was a 1978 merc 1750 V6 thunderbolt ignition. Starter seems to be the same size. Could replace that if necessary. Rectifier and solenoid seems compatible also. Wiring harness is not though. I may add I am using the key from the merc 1750 to start the 1500 since it didn't have one. Haven't hook up controls yet. Was thinking about using the quicksilver control from the 1750 instead of the mercontrol from 1500. Is that possible or hard to do. Also, if my switchbox is bad, can I use the switchbow from the 1750. I know it is different but I can rewire them. Where should I start???? I know I should check my harness, starter battery or cables first, but I seems to rotate just fine except for sticking to the flywheel. Grounding problems. Please help! Thanks
