8hp Yamaha, can't remove lower unit
PsyOrg
i took out the four bolts holding the lower unit, and it separated easily to a point. about six inches above the lower unit, it has a connection to the upper shift rod. i fully loosened the nut on the clamp. as much as i pulled and pounded, it wouldn't slide out. is there something else i have to undo? is there some pulling techinique i don't know?
please help. i'm a novice.
Warren
jl_photo
Re: 8hp Yamaha, can't remove lower unit
I think that the shift linkage clamp bolt must be completely removed, not just loosened.
go ahead and purchase a clymer or chilton repair manual it will save you a lot of frusration and money.
BruceAML
Purchase a Yamaha factory manual and not a generic manual. Never hammer and pound on anything unless you know exactly what you are doing.
isla
Blocking needed only unscrew
The auction is only inverter and the transmission shaft
Never use hammer!
rodbolt
some of the later model tiny mites have a shift rod seal and retainer bolted under the midsection. you have to seperate the shift link connector and fully remove the nut from the lower shift shaft so the shaft can pass through the seal retainer.
its actually in the correct Yamaha service manual as well as some of the marine tech guides. it may or may not be in a clymers or seloc. they tend to be a few years behind
rorypff
Great pictures Gianni - I always say a good picture tells a thousand words, thanks.
isla
Exactly! Engine that I know as my pockets, I did a tutorial on how to change the impeller, bearings, etc. etc. thermostat.
A disposal:)
PsyOrg
thanks. when i tried it, the whole thing broke. i hate outboards.
