javelin378
- Joined
- Nov 3, 2007
- 7
Hi everyone, I was hoping to get a little advice on my engine. It's a 89 110 evinrude v4 until yesterday it ran perfect but while fishing around the lake I noticed about the 3rd time I cranked up it seemed to have a noticeable miss. I assumed a fouled plug but there was noticeable loss of power, when I got home changed the plugs and one cylinder had some water residue in it. I started it a couple times on muffs but you could tell it's only running on 3 cyl. I did compression test and that cyl was holding 105 other cyl holding around 110 and I was hoping it's only a head gasket.I called one shop locally they want 45 to diagnose exact problem and 60 an hour for labor to work on it. I have a pretty good automotive background, work for a manufacturer, but this is my first outboard. I wonder if I am better off letting a shop do it or if this is pretty straightforward and I can do it myself.Also I have only owned the boat since May of this year so don't know much history on the motor other than it's original to the boat. I would appreciate any advice thanks.
