Suzuki help needed Pleazzzz
YOUWILLLOSE
I have a Suzuki DT-75 with serial number 07501-606406.
It is a White 2 stroke with oil injection, maybe a long shaft?
does anyone know what year is it and what transom height will it fit Please?
thank you very much
hopalong
Re: Suzuki help needed Pleazzzz
1986. The motor comes with a 25 in. or 20 in. model height. The 25 in. model lower unit does not have a spacer above the lower unit were the 25 in. does. The pic shows the 20 in. model
http://store.brownspoint.com/pdf/DT75_85(86-87).pdf
Here is a pic of my Suzuki, notice the configuration of the lower unit were it attaches to the motor above the cavitation plate. This is a 20 in. transom mount motor. If your DT75 is a 20 in. transom mount it would look the same in that area as my Suzuki. If it has a large 4in. + spacer there it would be a 25 in. transom mount motor. Hope this makes sense.
http://www.flickr.com/photos/12505056@N06/1302828249/
For more info go to www.brownspoint.com and click onto the parts diagram and go from there
YOUWILLLOSE
Hi, thanks for the info
where are you taking the measurement from as I thought the standard shaft was 18" and the lond 23" from transom mount to top of cav plate.
cheers
hopalong
OOPS, yes it is a 1986, my oversight
hopalong
cheers
Example, 115 Suzuki - From the bottom of the outboard motor bracket that sets on the transom to the cav plate for outboards is 20 in. for the short shaft or 25 in. for the long shaft motor. Transom heights differ a bit from others. You can elevate the motor some on the transom to get the correct level of the cav plate to bottom of boat V.
As per a 1994 Suzuki brochure 4-40 15 and 20 in.... 55-100 have only short shaft 20in. ....from 115 to 225 most all available both 20 and 25 in.
YOUWILLLOSE
Hi
thanks for all your help
I thought it sounded a little too new lol
great info thanks v much
