Ranger 330V
Thread starter- Joined
- Sep 25, 2007
- 242
got my engine running and its runnin well. Got the link and sync done and she purrs..idle sitting at 2-3degrees BTDC and set 24 degrees at idle. I was told on the water this will increase to the 28...well not told I read that, is this true? Anyways to the question. Everytime I have run the engine...still on stand and on muffs after I kill it and it sits for a while i have a black crude that comes from the small slot between the lower unit and the midsection. I'm guessing the gasket that seals the exhaust right there. I've run a gallon of gas through it so far sitting on the stand on muffs, this mix had seafoam in it, I figure it maybe carbon coming down out of the exhaust but why would if come out the front of the hole and not the through hub exhaust?? The motor is tilted slightly foward because it is on a straight stand. Thanks again for everyones help...I can't wait to get it on the water! Just little things now.
