Hello All,
New to the marine life, since I moved to FL and bought my 1st starter boat. I have a 14' Aero Glass with a Johnson 35hp(35el77h). I'm a complete novice and looking for recomendations, I'm not that happy with the current setup. I need a new control box as my gear shift cable has broken (I know have to manualy shift on the engine itself). The throttle also seems a little "quirky" which could be a few things, but I figured I would start with changing the control box out. What control box would be recomended? The current setup also is 1 battery(I keep a 2nd battery onboard though), but I would like to setup the boat if possible to run off of 2 batters and charge them via the alternator if that can be done?? If so how do I accomplish that? I would like to run my lights / live-well / GPS and not have to worry about changing around batters or having to remove 1 battery and charge in my home like I'm currently doing. Also propeller question?? I don't believe that I'm using the correct one or a better option is available any recomandations would be greatly appreaciated.
