Gale Sovereign 40 hp help
bull79
Hello everyone! I'm new to this boat stuff so please be easy with me. I have recently been given an old boat (no idea what it is still have to get the title)with an Gale Sovereign 40 hp model #40DE176L Serial #870170. I would like to get as much info. on this outboard as I can. I plan on restoring the boat and motor, so I would like to educate myself on what I have. If you need any more info. I will get it. Thanks in advance.
Re: Gale Sovereign 40 hp help
it was built by OMC johnson/evinrude, share most parts
"http://www.outboardbooks.com/index.cfm?fuseaction=items.main&boat=GP%20Gale%2FBuccaneer&orderby=model"
bull79
Thanks for the speedy response, but what is the difference between the bucaneers and the sovereigns? Also do you know if the manual is the same?The closest I come to the model # is 40DE17B.
that's as close as i got. the bucaneers are the only ones with DE in the model number.
steelespike
Not a Gale expert but to me the Bucaneer is simply the smaller and sometimes older model Gales.
I believe the Sovereign name was used only on the 40 and 60hp motors built 60-63.The 40 was built in 61,62,63 40DE17 is a 63 electric start.63 Was the last year for Gale production.These motors are basically identical to E/J motors of those years.In my aftermarket manual repair procedures are covered in the same section as E/J motors with no Gale specific reference.
Your specs are 43.9 cu. in.40hp @ 4,500 rpm,Champion J4J(J4C)plugs set at .030,Points set at .020. 24:1 fuel mix.Same as the E/J motors.Many routine maintenance parts are available right here at Iboats under the E/J applications.Also at well established E/J dealers and NAPA auto parts.
Some NAPA branches don't know about their 600 page Marine products catalog.
bull79
Thanks for all of the help. Now I at least know the year and some basic info on the motor. Thanks for the specs Steelespike now I can feel safe about plugs and fuel mix.
