Texasmark
- Joined
- Dec 20, 2005
- 14,981
Was filling up the livewell day B4 yesterday and started getting some real intermittent operation out of the fill pump. Didn't know if the switch was going bad or the motor. Checked it out yesterday.
Problem solved: shot the spade terminals on the switch with WD-40 and moved them back and forth half dozen times. Apparently had some corrosion there (fresh water use) and the wire couldn't make good connection.
Don't think the worse when things happen. Sometimes it's just a little housekeeping is all that's required.
Mark
Mark
