a70eliminator
- Joined
- Sep 9, 2007
- 3,762
Hi, my trailer came factory equiped with Reliable Sure Lube hubs with drum brakes. I have an issue with grease slinging out around the hubs and splattering the rims with grease, I found both of the plastic grease caps have cracked, is there any reason why I couldn't just replace the plastic caps with bearing buddys which are stainless steel and have that spring in them? I just can't find the correct sure lube caps anywhere locally where as the bearing buddy caps are everywhere.
