Ugly oil leaking from prop
deriz
I have some ugly oil/grease/water mixture leaking from the prop. any idea what this could be about?
Thanks
samo_ott
Re: Ugly oil leaking from prop
TD, you're good with those links! How the heck do you keep track of em all?
deriz
Great link, thank you. I smelled the oil, smelled like two stroke so that solves that. But my gear oil was a little milky, i was told to jb weld a little hole in the shaft, but the hole looks like it is meant to be there. The motor is a 1987 johnson 9.9. any suggestions?
Thanks again
Gary H NC
JB weld is not going to stop a gear case leak.
What hole and who told you to plug it with JB?
Solittle
Install new o-rings/seals on the fill & drain plugs, fill with fresh gear oil and run it - then retest. If you are lucky that will do it.
1730V
Exactly. Everybody freaks out on the oil leak issue. The above says it all. Don't overdiagnose it.
HighTrim
Agree, those drain and vent gaskets are the number 1 spot for water intrusion. Fill it with full synthetic lu oil, change those gaskets, and run it for a bit before checking it again. The water will sit at the bottom of the lower unit, so just need to empty a bit to determine if you have a breach. If it is still leaking, you will need to do a pressure/vaccuum test.
To pressure/vacuum test a lower unit:
a) drain the gear oil
b) use an appropriate adapter with a gauge tee'd in to apply pressure or vacuum. No more than 15 psig for pressure. You can use a bicycle pump or any other compressed air source for pressure. For vacuum, you need a vacuum pump.
c) LU should retain some pressure or vacuum for 45 minutes minimum.
d) If pressure doesn't hold, submerge LU in water to find leak source [possibilities: drive shaft seal, prop shaft seal(s) (usually two), shift shaft seal and the fill/drain screw washers.]
e) replace offending seal(s) as required.
deriz
cool, i will try replacing the o-rings. hopefully that will do it.
Thanks again
