FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
How long should it take for t stat to open and for water to come out of exhast holes middle ways up leg housing? Pee hole sprays water like a champ. 1978 25 Johnson
What you have there are 2 seperate questions. Should only take a few seconds for the spent cooling water to exit via the exhaust. The t stats opening however are not based on time, rather water temp, and I believe in you case that temp is around 145 degrees.
Is this the same 25 hp you've been working on the water pump? If so, sounds like you've got 'er pumpin'. Great! Are you getting close to fixing it for good?
Interested to hear some good news!
JBJ
Alright took to lake still not pumping water out of exhaust hole. Brought home and removed T stat. Started motor in deep bucket and water sprays out of pee hole and gushes out of t stat hole. But with tstat in place no water is coming out of exhaust holes. The T Stat is brand new also. Could there be a clog from tstat to exhasut holes?
