Chrysler Magna Ignition
Ash Lewis
G'Day I am a brand new member. I am having troubles with my Chrysler 75hp 3 cyl outboard. Model 757HB ('75 - '79) Serial No. 16965.
The motor will fire quite easily. However will stall under load. The carburettors have been removed jets cleaned and replaced.
I believe it may be an ignition timing issue, the engine runs a Magna Ignition, silver box with black sticker & orange writing.
Help would be appreciated.
sailingwest
Re: Chrysler Magna Ignition
sorry cant help ,just got an 85 with the same problem ie ign,the engine is in mint condition but the guy i got it from said it just needed switchbox replaced .lower unit is as smooth as silk and all compressions good ,carb mouths have wax paper sealing them. Looks like a good one .If i find anything out i will let you know......Jim B
Ash Lewis
Jim,
Thanks for the reply.
I have since replaced the coil and that appears to have corrected the problem.
May be worth a try
Cheers
Ash
sailingwest
cheers ash, got mine running too, got a cdi module shipped from the states for less then half i could buy it for in the uk, engine is a winner compressions 150 ,150, 148 have it hanging on the back of a 14ft fletcher arrow have not run to wot yet its too scarey .use it on loch lomand 24 miles long ,run out of lake real quick .glad to hear you got sorted sorry i could not help.Jim B
sailingwest
ps, the cdi ref is 1153301 by cdi electronics it replaces the cdi unit and coil in one unit...Jim B
