smoke alarms
Bob_VT
I just came from a seminar about "fire/home safety" and learned quite a bit about smoke alarms and saw a few nice products.
What kind of smoke alarms does everyone use? This was about Master Guard products.
BoatBuoy
Re: smoke alarms
I think all 5 of mine are Kidde, if you're asking about brand. Just replaced my CO detector due to age and plan to start replacing my smoke detectors this next year.
Since you've been to "alarm academy", what tips can you share?
Bob_VT
Re: smoke alarms
The most disturbing was the failure rate and what is actually listed in the instruction manuals..... failure rate is almost 40% The standard smoke detectors are all basically the same type of detection ionization and they have a high failure rate..... yet approved for home use! The ones I saw last night were photoelectric with a lower failure rate. A smoke alarm has a life of only 8-10 years.
The summary is you need to use both.
It was a real DOOM and GLOOM presentation. I am not impressed by being told I will die in a fire..... hell I am going to die anyway.
I also saw a very impressive heat activated fire bell louder than an alarm clock but based on the same principle .... a big strong wind up main spring activated by a thermal fuse set at 117 degrees. LOUD!
i386
Re: smoke alarms
Mine work. My wife's cooking is a testament to that.:D
Seriously though. Mine are more than 8 years old. It wouldn't be a bad idea to replace them. They're not that expensive.
heyttown
Tyme2fish
Re: smoke alarms
I used to have a sign in the kitchen that said,"When the smoke alarm goes off, dinner is ready."
Caveman Charlie
Re: smoke alarms
My own cooking sets mine off once and awhile. It is quite old though and should be replaced. If your a tennant in MN your landlord is suppose to, by law, provide a smoke/ carbon monoxide detector for each floor and or bedroom of the house. I have one on the main floor and that's it. Nobody sleeps up stairs anyway. And the basement is just a moldy pit.
v1_0
Re: smoke alarms
Mounting the Smoke detector up high, and a seperate CO2 detector down low seems a better route. Being that CO2 is heavier than air....
For the kitchen, there are "heat detectors" that sense heat rather than smoke.
-V
Caveman Charlie
Re: smoke alarms
A propane detector for my camper. Or, even a house. Seems like a good idea to me. But, there expensive and difficult to find.
BoatBuoy
Re: smoke alarms
-V
Why would anyone need a CO2 detector?
v1_0
Re: smoke alarms
If you heat with anything other than pure electric (heat pump, heat strips, etc) and/or solar. And don't have an attached garage...
Oil/gas/wood stove heating can give off CO2.
Everyone needs to decide for themselves what the risk of CO2 is - right now I heat with a heat pump, so I don't feel the need to install a CO2 detector. However when I get either (or both) of the fireplaces up and running - then I will certainly install CO2 detectors.
-V
BoatBuoy
Re: smoke alarms
Be very afraid of carbonated drinks and beer. They both give off a lot of CO2.
Caveman Charlie
Re: smoke alarms
-V
:rolleyes:I think there giving you grief.:p You mean Carbon Monoxide, not CO2. There two different gasses. ;)
Re: smoke alarms
All the ones mentioned in the Consumer Reports article were battery only powered. Are there any hardwired AC models that are dual sensor?
Bob_VT
Re: smoke alarms
Kidde does but read the very last line :eek:
This 85-decibel smoke alarm provides superior protection in bedroom and living room areas. It has a photoelectric sensor to quickly detect slow-burning smoldering fires. It also has an ionization sensor to quickly detect fast flaming fires. The alarm includes a front-mounted hush button to silence any nuisance alarms, along with a test/reset button to verify operation any time.
This alarm is the hard-wired model, can be interconected with up to 24 other units, and has a battery backup in the event of a power outage.
Manufacturer Warranty: 5 Years
Instructions: English & Spanish
Temperature Range: 40 degres Fahrenheit (4.4 deg/ C) to 100 degrees Fahrenheit (37.8 deg. C)
Compliances: UL, FHA, HUD, NFPA, CA State Fire Marshall
Origin: China
