Chad D
Thread starter- Joined
- Apr 27, 2007
- 47
I was looking in the engine compartment last night and was looking at the back corner of the boat at the transom. I was pushing with my hand to make sure it was solid. the back of my boat has a wierd shape to it. the almost the entire area on the transom is glassed on the inside except for a small area on the back. (marked with the red box in pic) I found a small spot in the plywood back there that is cracking when I push on it, not bad and its not wet but it gives a little.(yellow box) if I go the the outside and push in that area it is solid. my question, is there a temporay fix I can do just to get me through next season as I do not have anywhere to take the boat appart and fix it right. I am planning on replacing everything, stringers transom deck all of it next winter when I will have a place to do it. could I add a couple of layers of glass to get me through, and is that anything structual there. I only have two stringers that run the length of the boat at the width of the engine
