brettagostini
Thread starter- Joined
- Jul 14, 2003
- 77
I'm trying to pull the prop shaft on an '81 140 Evinrude. The manual shows the use of a disc-shaped flywheel puller that has two bolts passing through it which are fastened into the prop shaft guide piece. (Whatever its called.)
But all the autopart stores I've been to only have flywheel pullers that look like grappling hooks.... you know, the three arms that hook around the edges of the flywheel. This will not work on the propshaft.
Is there another way to pull the shaft, or do you know where I can track down this puller? (Perhaps sears.... this just occurred to me.)
Thanks.
Thanks.
