HELP Jack Plate Question
beeshanowa24
I don't know if this is the wrong forum or not. I have a 13 foot whaler with a low transom and I can get a steal of a deal on a 40 Yamaha with a long shaft but on the Yamaha the tilt is broken so I want to find a jack plate that I can manually tilt it and it will raise the motor like 5 inches or whatever I need. So if any one can help me that would be great.
Gary H NC
Re: HELP Jack Plate Question
They make many different size jackplates.You can get manual or powered lift.
I think what you are saying is you need the engine higher due to the long shaft and be able to tilt it also.Those plates get really expensive.Do a google search for jackplates or transom brackets and you will find all kinds.
Willyclay
Try: bobsmachine.com and cook-mfg.com. Good luck with your project!
A jackplate will raise the engine but it won't tilt it! Therefore it's only use would be to compensate for the long shaft. You might be money ahead looking for a short shaft lower unit, making that swap and then fixing the tilt unit and having a much better setup in the process.
There has to be a jack plate that tilts.
Not Really,.............
Most Jack Plates are used with motors that Already have Trim,+ Tilt..........
Btw,..............
Even a Free motor,...... If it doesn't fit your application,.........
Isn't much Good, Nor Free after you spent more than it's Worth to Cobble it onto a boat it Still Doesn't Fit........
beeshanowa24
well that sucks, well is there one that fits my application but doesn't tilt?
vmaxjay
Jack plates are designed for optimizing performance by "raising" the motor off the transom & putting it back further, but not by "tilting / trimming" the motor out. They are also used on flats boats to aid in shallow water running as well as performance! You're not going to find one that tilts. Sorry!
