Bmw M3 Guy
Thread starter- Joined
- Dec 5, 2007
- 5
Today I looked under the prop and there was a puddle of oil. At 1st I thought it was the final drive lower unit oil. Maybe a bad gasket or a loose bolt from the side. It appeared to be leaking between the prop and the lower unit. 1st I took out the two bolts on the right hand side of the lower unit seen in the pictures below and let it drain. After completely draining I decided to take off the prop. Sure enough I noticed a collection of oil and smelled to be unburned 2 stroke oil. Since the prop is used for the exhaust I felt everything was ok. I know you guys are the experts and would like your input on this with viewing the pictures below.
The boat was last taken out 3 days ago and everything functioned correctly. Power was there and gas is always mixed properly.
2 question I have is this normal for oil to leak?
Also, since I drained the lower unit final drive, how much oil is required upon re-fill?
Thanks,
Justin
___________________________
Thanks,
Justin
