Re: 1989 Bogs and shuts off after WOT
Thanks for help. Quick question when the bulb isnt connected to the motor 3 squeeze and its hard, but once i connect it to the motor it would never get hard. So does that mean my bulb is bad? Another thing i notice on the test run is when im going about 10 mph for 10 mins my motor will slowly shake and bog as it has no gas, once squeeze and it will fix it right up and i can go for another 5 mins or so. So for sure i know it aint getting enough fuel am i correct?
Can someone link me direction how to clean and take apart the carb and fuel pump please. thanks in advance
You can develop 10 lbs or more of pressure with the primer bulb. 7 or so will overpower the floats in the carbs, and flood them. You should be able to see that with the air cover off. If it isn't going there, you have a hole in the fuel pump diaphragm. From your symptoms, it's either that or a hole in the fuel line before the pump (most likely right at the primer bulb) or a plugged tank vent.
The fuel pump kit comes with directions. 4 screws and about 8 other parts. You can do it. Be sure the pulse line between the fuel pump and the crankcase (or reed plate) is stock and in good shape. A tygon, or mushy rubber line will absorb the pulses and make the fuel pump very weak. While you're at it, make sure the crankcase fitting isn't plugged. You should be able to wrap a lip lock on the pulse line and blow freely into it.
When I was trouble shooting mine, I teed a line into the fuel line just before the carbs and put a pressure gauge right in my lap. When it failed, fuel pressure would go to zero.
That engine needs about 18 GPH at WOT. An aftermarket bayonet (plastic) will not pass that amount of fuel period. I just chit canned mine and hooked it up direct to the oil mixer.
Cheep, aftermarket fuel line also will not deliver that much fuel. At that flow rate, a rough finish on the hose inner tube will cause it to starve. Use Mercury line.
RACOR 60 gph water seperating fuel filter; worth it weight in gold.
If you install the RACOR filter and bypass the bayonet, you can safely chit can the internal thumb sized filter eliminating another common trouble spot.
Find the little fuel vent fitting, usually on one of the gunwales. Check it for a mud dauber nest.
I put a RACOR vent check valve in my vent line. Now I can run a full tank without splashing gas out the vent. It was hard to get in with the limited elevation, but it went in and works well.
When you get it all figured out, be sure you wear a life vest and use the kill switch. It'll go past fast to wild.
hope it helps
John
