TACH questions - '81 90 HP
metriccrescentwrench
I want to add a tachometer to my recently purchased boat.
In outboard terminology is "12 Poles" the same as "12 Pulses"? What will I need for my motor?
On the 3 pinned plug that's beneath the throttle friction lock, it's got the purple hot wire on it but not the grey tach signal or the ground. I can probably locate pins that will fit the plug but need to know which signal wire goes to which position.
thanks
guy74
Re: TACH questions - '81 90 HP
Hi,
Your motor is 12 pole, which means you need to set the tach for 6 pulses. The wiring on the plug should be BLK-GRY-PUR, looking at the rear of the control. The center gray wire in the plug is toward the bottom.
Sincerely,
Brian
Thanks Brian.
So then, as a check of the tach's accuracy, I should be able to use the frequency counter on my multi-meter and divide by 6 to get the engine speed, right?
72SideWinderSS
Thanks Brian.
Freq. X 10 = RPMs.
I use a signal generator to calibrate my tachometer.
