1996 Evinrude 130hp
david565L
Yesterday i went out and after about 5mins of driving a constent beep started sounding and the motor just slowed right down and as id rev the motor it was just reving out like i had spun a prop
the beep stopped after about 30secs, after about 1min the motor run fine for rest of day
what could this be?
Re: 1996 Evinrude 130hp
cooling blockage, or lack of oil to the vro pump. which probably corrected itself.
david565L
another thing is when i got home i noticed that the water coming out the motor is boiling hot is this normal
aswell as that when i take the boat of the trailer at the ramp it starts no probs i go to dock after a couple of mins motor cuts out like its not reving hard enough
then if i start again quickly drive off motor is good
Solittle
And when did you replace the water pump & thermostats last?
david565L
Water Pump And Both Thermostats Got Replaced About 3 Days Ago
