jbjennings
- Joined
- Jul 18, 2007
- 3,903
Laddies, I read your info on the 7.5 carb needing fuel squirted into and have a similar problem. After the same squirting need, I decided to rebuild it. I noticed on the float where the needle valve sits that the top of the needle valve had either worn a little dimple in the float lever or was sitting in a dimple that was supposed to be there. I've cleaned the carb and noticed that when I filled the carb bowl with the primer bulb, quite a bit of gas spit out the little brass thing on the carb throat. It cranked right up with no help and ran GREAT for about 5 min. then died. The float valve was stuck closed (I couldn't squeeze the bulb), then it finally opened and wouldn't close (flooded out , I took off the fuel connector, got it to crank again, connected the fuel hose and it started spitting a big stream of gas out that brass nipple in front of the carb). I know I have the float adjusted wrong and am going to fix it, but first, I have a couple of questions:
1. Is this little brass nipple that is in front of the carb throat supposed to prime the engine when you pump the bulb?
2. Is the float lever the needle valve sits on supposed to have that dimple?
3. If it's not, can I fill the dimple and fix my adjustment problem or get a new float? ( I think it might be slipping down in that dimple)
Thanks,
JBJennings
Thanks,
JBJennings
