cc67
- Joined
- Nov 4, 2007
- 365
I did a search but didn't get the answer I was looking for. Installed new points,coils and condensers this morning and everything went together fine.Engine turns easily using the prop in gear to set points. I cleaned the mating surfaces and installed the flywheel, snugged it and then torqued to 45 lbs. It's binding on something and won't turn very far. I took it off and tried again,same thing. So is there a trick to this? I'm sure it's nothing major. I used OMC parts.
