Re: new at this
We are very happy that you have a 4.3 Merc -- however when it comes to props you need to provide us with a little more to go on. Like:
1) What boat make model, length and weight if possible
2) What prop (manufacturer, stainless or aluminum, diameter and pitch) does it have now
3) what is the current observed wide open throttle operation with an average load
4) what is the current observed wide open throttle speed with an averaage load.
5) do you tow water toys, ski or wakeboard?
6) Does the boat currently have trouble getting on plane?
7) Any performance issues you want to solve. Sorry -- Doubling your fuel economy is not possible.
You see -- saying you have a 4.3 Merc is like me saying I have boat -- what prop do I need. The prop is the transmission for your boat and it has only one gear (as in high gear for your car). It needs to get the boat out of the hole, cruise comfortably and keep the engine in its recommended wide open throttle rpm band. Give us some numbers to work with and we can help.
