you think any of these controlers will work?
BigB9000
linkys:
url]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=280180578823&ssPageName=STRK:MEWA:IT&ih=018[/url]
url]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130180575232&ssPageName=STRK:MEWA:IT&ih=003[/url]
url]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130180654692&ssPageName=STRK:MEWA:IT&ih=003[/url]
url]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130181574116&ssPageName=STRK:MEWA:IT&ih=003[/url]
ah? ah?
(oh, this will be going onto my 1991 johnson 20 hp)
wildmaninal
Re: you think any of these controlers will work?
Allot of them you posted may not work, those 2 lever controls are a little bit older setups I'm pretty sure of that. This link here might be the closest one to what you might need. Same link you have in your post by the way, I just copied it and pasted it here to refer you to it.
"http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=003"
Will the wire harness plug into your motor also? That is question to ask. Obviously your 20hp is setup for a console steer not a tiller steer correct.
I also say it is hard to tell what will fit it with out seeing the ends of the cables. Just my 2 cents. DJ or any of these other guys will be able to point ya in the right direction.
Another thing you can do is email the seller on ebay and ask what year motor the control box was used for. I might be wrong they might work fine but again it is hard to say with out seeing the ends on the cables and harness.
BigB9000
actually no, my enging currently has the tiller set-up. I ordered the conversion kit from the (or A) dealer last friday, so it should be here wensday.
harness isnt a problem, as my engine is pull-start, so all it will use is a off/on switch. which is included in the kit I ordered.
all I really need now is a control box, and some cables.
on a side note, i looked into the kit to make it electric start, cost is almost $500 :eek:
...at that price Ill continue to pull the cord. or buy an engine thats already electric.
BigB9000
shifter:
throttle:
