impeller question
wv_boater
I'm changing the impeller on my '96 25 hp (recently purchased) and the metal housing that the impeller sits in (insert cup) has a black deposit on about 75% of the surface that the impeller rotates on. Obviously, the black deposit is the rubber from the impeller. btw....I ran the engine prior to pulling off the lower unit and it was not pumping any water. I then proceded to remove the bottom plate and underneath it where the water flows was completely clogged with maggots!! Reason for no water flow. The question is, should I be concerned about blockage farther up in the system and if so, how to go about removing it.
AGENT 37
Re: impeller question
I would blow compressed air back down through the cooling system from the water indicator outlet with the lower unit removed. You can put your hand over the pick-up tube and feel good airflow when it is clear.
