j442w30
Thread starter- Joined
- Jan 9, 2007
- 264
Ok I posted about a month ago when I found burned wires that connect the stator to the rectifier on my 1993 Mercury 40 hp outboard. After looking at the wiring some more I think that I have the wrong stator. According to the wiring diagram in my service manual I should have a 6 wire stator and right now my stator only has 4 wires, 2 of which go to this box and then connect to the switchbox. Because I only have a 4 wire stator there are 2 open posts on my switchbox. I should mention that the engine runs fine but I am concerned about the burned wires and high voltage doing damage to the electrical system
Heres a picture of the two burned yellow wires, last winter I had to replace the rectifier because the plastic around the terminals had melted a little bit.
I removed the stator and found that of the 4 wires total, there are 2 yellow wires that go to the rectifier and a green and a green/white that go to this box thing which has blue and blue/white on the other end which go to the switch box. I took the serial numbers off this stator and cross referenced them on the CDI site and supposedly this stator goes to a OMC engine.
Heres a picture of the stator and box, does anyone know what this black box is?
Now here is the page from my service manual that shows how it should be with the six wire stator.
Now I assume I have the wrong stator, should I ditch what I have now and get the six wire stator? Will this fix the burnt wire problem? My engine has the rectifier setup, not the voltage regular, does anyone know what stator is correct for my engine? I've been looking around and I think I found the right one, its CDI part # 174-5454 K1. Can anyone confirm this?
Sorry about the long post but this really confused me.
Thanks
Thanks
