Ranger
JB
Re: Ranger
Probably if it weighs about 1,000 to 1,500lb, including any engine, gas, battery, onboard equipment and the trailer.
Re: Ranger
i have a Mercury Mariner (Ford Escape), 2.3L automatic. i tow up to 2,000 lbs with it with no problems. of course i'm in the flat lands of Florida. i have taken several boats to North Carolina, in the mountains, i wished i had the 3.0 6cyl. i have pull 4,000 with it a very short distance, but it really did not like it. we have a 1999 Surburban 5.7L to pull the bigger boats.
rndn
Re: Ranger
Welcome to the forum. You can tow something very small as stated above. I would stick with something around 1k total weight.
JB
Re: Ranger
Daddy mentioned that his Mariner is an automatic. That makes a big difference over the 5 speed in towing capacity. My daughter's Ranger 2.4 5 speed barely towed itself.
reelfishin
Re: Ranger
I have a '94 4x2 Ranger with a long bed and 5 speed manual trans, I have towed as much as 5500 lbs or so, but the most I feel it can comfortably launch at the ramp is about 1500 lbs, due to lack of traction. It's not fast but it does get the job done. Depending on the ramp condition and how the boat is balanced, you may be able to get away with towing or at least launching a bit more. Mine has the tallest gears and no towing options other than the hitch I added and it gets the job done, (and has for 122,000 miles).
maxturbo
Re: Ranger
I have a 2000 ranger 4x4 with a 3.0l auto. 4:10 gears and I had a real hard time towing my 21' boat. To the point where I had to stop and call my friend to bring his truck. Now I'm selling her to get a bigger truck. Gonna miss her, she never let me down.:(
Guess it all depends on how big the boat is. Dont forget to add the weight of the trailer, motor, gas, equiptment and anything else you have on it.
CATransplant
Re: Ranger
I have a 2000 Ford Ranger 2.5 L can I tow a boat ?
You could tow my boat. Trailer, motor, boat, and everything in it weighs less than 600 lb. I tow it with a 1991 4 cylinder Volvo station wagon, and you'd never know it was back there.
It all depends on what kind of boat you have or want to have.
Titanium48
Re: Ranger
You can tow more than that with a Corolla. The lowest tow rating for a 2000 Ranger is 1580 lbs.
eric136
Re: Ranger
Accelerating and maintaining speed is one thing but stopping is something that definitely needs to be considered.
Titanium48
Re: Ranger
^ Which is why trailer brakes are a good idea whenever you are towing something heavier than about 50% of your vehicle's curb weight. I wouldn't hesitate to tow 3000+ lbs with a small truck, but I wouldn't go much over 1500 lbs without trailer brakes. I also wouldn't want to be trying to haul a 3000 lb boat out of the water with a small truck unless it was a 4x4.
jfadool
Re: Ranger
Yes,
I had a 97 ex-cab, 2.3 5speed. I was able to safely tow a 13' whaler, engine, trailer, and gas.
On the slick ramps I had to be careful but the whole trailer setup only weighed 1400-1600lbs(yes I used a scale)
That truck was no speed demon without a trailer and with one it was slower but only a small amount. The breaks were the limiting factor. I had drum rears and with some weight behind it, stopping distances were longer. But would I do it again, absolutely.
Check the weight of your rig, use a scale not NADA or something else, check your owners manual and compare the numbers.
If you are planning on towing a 18ft bowrider you will need a different truck. But a 14ft aluminum skiff would most likely be just fine.
dave11
Re: Ranger
Find out what the actual towing limits are. Don't tow any more weight than that. A reasonable safety cushion would be to only pull 75 to 80% of the tow rating.
rosser1
Re: Ranger
I have a 93 ford ranger and I have a 17ft bass boat the bumper says 2000lbs limit, not sure what boat weights, but i know i have had firewood in bed with mud flaps dragging ground and it pulls great. 4 cyinder, 5speed. Did have to replace clucth the other month. but truck has 150,000 miles so it was time for maintaince on clucth. But boat doesn't weight that much i know and have had no problem with pulling. Like the other dude said you do have to give time and room for stopping.
reelfishin
Re: Ranger
I guess since this thread has been brought back up I'll add to it again.
I used a 1999 4x2 Ranger to tow a 2500lb boat from NJ to southern FL last fall, plus the bed was loaded with misc items as was the boat. I wouldn't try to launch that kind of weight but it did just fine down I95 the whole way. I had no issues at all, it drove fine, got decent mileage, and made it in no more time than I normally take for that ride.
The boat was an old trihull, plus we loaded it with several other items that needed to go too, probably another 800lbs or so, and the bed had loads of tackle and boxes of misc. household items like glasses, dishes, etc. A buddy was moving there and we took turns driving his three vehicles.
I'm not saying it didn't feel the weight but it did the job just fine, stopped fine, and handled fine. It wasn't going to win any races but it had no problem keeping up with traffic.
It made me really wish mine had the 3.0L engine.
I think if they still offered that motor, I'd go buy a brand new one today. But I'm just not game on having an American truck with a foreign motor. Its bad enough the trans in my 1994 is Asian, as was the trans in the 1999 I drove to FL.
The week point of the Ford Ranger is the trans/clutch set up, every one of these I've owned has had some sort of clutch or shifting issue most of its life. Mind you, none have ever failed and left me on the road. The auto trans is even worse in the older models, and from what I hear not much better in the newer trucks.
I pull a 2200 lb 18 1/2' aluminum boat, a 2500lb glass trihull, and an array of smaller trailers with my 1994, and have pulled a tandem axle landscape type trailer for years with it with no issues. Mine being a 2.3L is slow to get rolling but a gear change would solve that. My last Ranger had 4.10 gears and it did great with a larger trailer.
When it comes to traction, in some cases, the Ranger does better than my one ton Dodge van, which will get stuck on wet grass, but does tow on flat land just fine.
Re: Ranger
I tow my Wellcraft 170 I/O with a 2000 Ranger Super cab 4X4, 3.0l auto. Tows it fine, but I added electric brakes to the trailer, because I wanted to be able to stop too. It tows pretty good on the smaller hills here in NW PA, but I don't want to try pulling up the bigger hills to the south with it. As for the ramps, the Army Corp ranch at Shenango reservoir where I launch is pretty steep, I always use 4 Low to pull out of the water there, and when I am towing I always lock out the overdrive.
