Joe Reeves
- Joined
- Feb 24, 2002
- 13,262
Re: 1986 evinrude 140 question
Greg... You say "it does not have a steady idle, it moreless fluctuates".
A slow rpm roll up and down could be caused by a fuel/air leak at some point between the fuel pump and the fuel supply.... OR by having the linkages between the carburetors not synchronized, that is having one butterfly ever so slightly open in relation to the others.
A microsecond interuption (popping, spiting back) is usually caused by a fouled or lean setting carburetor as mentioned previously.
A sudden instantenous drop in rpms, and a later just as sudden and instantenous regain of those rpms has always proven to be an ignition problem. I've never encountered a powerpack to be the cause of this type problem. This is usually due to a failing coil, spark plug, something of that nature.
S/Plugs should be Champion QL77JC4 plugs, gapped at .040. Check the continuity of the plug wires and coils as follows.
(Magneto Capacitance Discharge Coils - Continuity Test))
(J. Reeves)
Check the continuity of the ignition coils. Remove the primary orange wire from whatever it's connected to. It may be connected to a powerpack screw type terminal, a rubber plug connector, or it may simply plug onto a small boss terminal of the coil itself.
Connect the black lead of a ohm meter to the spark plug boot terminal, then with the red ohm meter lead, touch the ground of the coil or the powerhead itself if the coil is still installed.
Then touch (still with the red lead) the orange wire if it's attached to the coil, or if it's not attached, touch the primary stud of the coil. You should get a reading on both touches (contacts). If not, check the spring terminal inside the rubber boots of the spark plug wire. Poor or no continuity of a coil is one reason for s/plug fouling.
When time permits, visit my store (copy/paste) at: stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
(J. Reeves)
