Hi Folks,
I have a 1975 115 Johnson outboard that starts and runs well. After taking it out today I noticed that water is not coming out of the outlets as it was this morning, and that it is running quite a bit hotter than when I pulled it out of the water today. I want to remove the lower unit and replace the water pump impeller. I have separated the lower unit with the exception of the shifting rod. I see that there is a rocker assembly that attaches to the rod under the carbs but I don't see how it is attached and can't imagine getting in there to do anything. What is the trick to this?
Also, where can I get a water pump kit for it and what should I be looking out for.
Thanks for your help,
WayneV
WayneV
